Indesit 1W C6125
  • #71716
    newgas
    This washing machine has been making a noise when working recently.
    Engineer was called out and changed the 3 plastic sections inside the drum ( forgot what they are called) 😀 .
    It worked for one wash but now it has stopped working altogether, the machine switches on but when asked to go into any cycle it revolves for about 1 turn then just stops.
    Any ideas?
    TIA
    #382037
    Re: Indesit 1W C6125
    Are you getting any lights flashing or error messages?
    #382038
    newgas
    Just a solid red light with a lock symbol next to it , but I think that is the door light.
    No error message.
    #382039
    Model is an IWC6125. 😉
    Hard to say really, these machines are such a pile of poop that anything is possible, checking the obvious such as motor brushes, motor wiring connections and all other wiring is the first step, an insulation test on the motor and heater next.
    #382040
    newgas
    I talked to owner and theys say the engineer who came out checked the stuff with his meter and said the circuit bord is faulty.
    Why the winky?
    I know the model no. , cos I put it there.
    #382041
    If you look carefully at my post you will see that I have highlighted the letter I by making it bold.
    The model number is IWC6125, not 1(one)WC6125. 😉 😉
    The electronics on these are dreadful and are usually the source of most faults after the obvious things have been eliminated. 🙁
    #382042
    newgas
    Thanks for the clarification, I am gonna have a go at the search facilty with an I instead of a 1
    #382043
    madangler1
    Check the basics, brushes then motor harness. If they are fine 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} the board hs gome.
    #382044
    newgas
    How much is board roughly?
    #382045
    Board is about £80.00, smart card needed to program it, £16.00, card reader needed to use the card to programme the board £100.
    Send it to EMW if you suspect it is faulty, they will test for a small fee or repair it for you.
