indesit :(
  • #19991
    DDSDDS
    right folks i have an indesit just taken it away from customer sold them a new one
    just done the bearing put it on a test and the machine goes throguh the cycle wonderfully
    but there is no heat at all
    the model number on the back is w113 uk
    but on the fascia it is w83
    i am assuming that someone has changed the wiring harness at some point and i also assume that w83 is the correct number 😕
    i have checked heater it is fine the thermistor reads at about 25 ohms
    i also had 2 modules to hand and have tried them both just to get the same fault i have tryed a program 4 i also checked the economy button as there was superglue on it
    it read through ok but i changed it anyway
    so any ideas i wanna try a p switch but dont have one here till a few days time so if any one has seen this or can tell me there thoughts then as always ta very much
    #185330
    Martin114
    Re: indesit 🙁
    I think 25ohms is a very low reading for the thermister, I would have expected it to in the Kohms range. May be it thinks its already hot enough.
    DDSDDS
    Re: indesit 🙁
    sorry martin my mistake it is 25kohms
    and it is on my testing bays which are all cold fill pipes only does not even get tepid
    certainly could not have a bath in it lol
    frostbite
    #185332
    Martin114
    Re: indesit 🙁
    Could be the pcb relay if all else looks ok.
    this may be of interest:
    http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&t=11142&postdays=0&postorder=asc&start=0
    #185333
    DDSDDS
    Re: indesit 🙁
    any one any thoughs have found a p switch tryed that but to no avail
    only things left are valves and d’lock
    cant find any scored wires
    :rolls:
    #185334
    DDSDDS
    Re: indesit 🙁
    one of the first things i did was to change heater relay followed by the board
    followed by another board
    baffled
    #185335
    Re: indesit 🙁
    IMHO they are not worth sorting to sell as recon. machines. I was using a W103UK for a while until the bearings went. I didn’t bother trying to repair it as I just don’t have enough confidence in these modern Merloni machines to sell them with a guarantee. You get leaky tub joints, suspension units ripped out of the base, dodgy modules etc etc.
    #185336
    matkins
    Re: indesit 🙁
    🙁 We all have to make a living but unfortunately I agree with the previous posting, Easy fix Merloni dont stand any guarantee period you may offer in most cases and end up costing too much time ultimately money. 🙁
    #185337
    DDSDDS
    Re: indesit 🙁
    ok lads pretty much my thinking anyway but it was clean and i believed th3e customer who said it works just noisy
    but at the minute i have plenty of stuff to sell and an empty workshop till this weekend only this and a hotpoint tdl 11 felt to fit so got plenty of time to play about with it
    more of a challenge i do not like to admit defeat especilly when i have the time
    so todays plan
    try anohter module heater and thermistor in that order
    then change all the bits one by one lol
    if i do manage to find out what it was i will let u know it has till tommorow afternoon toget its arse in gear
    #185338
    Re: indesit 🙁
    DDSDDS wrote: a hotpoint tdl 11 felt to fit
    Only a temporary fix changing the felt seal, a full drum & duct kit is the only ‘long term’ repair for seal failure on all pre date code 07 machines.
    #185339
    DDSDDS
    Re: indesit 🙁
    tbh i have only seen 3 of these including this one and the other 2 where felsts also
    i did suspect common fault when i saw this one but have not heard anything of it
    drum and duct kit
    do you have a price on this and is it a good repair or will i still get the same fault
    or do i just throw it outside and let loose with my hammer 😈
    #185340
    Re: indesit 🙁
    Drum & duct kit, includes complete plastic duct assy & filter and reverts back to the old style bearing pads, inner drum, stats, extra fan, rear back panel and all seals. Part number 1702495, list price just under £50 ex vat.
    A good repair but pricy.
    NB. If you do order one of these be sure to check the contents of the box, I have had several and I would guess that 1 in 3 have been damaged in transit. 😥
    #185341
    DDSDDS
    Re: indesit 🙁
    right folkjs just to update on the indesit after several more attempts on friday and some thought over the weekend i came into work this morning through the buggar out kicked it several times and rang my scrappy to take it away
    beaten by an indesit the shame of it
