indesit 5 flashes
  • #32872
    kev00
    hi i have a indesit w161 washing machine it as just stopped during a cycle the control knob keeps turning and the light is flashing 5 times does any body know what the error could be
    thanks in advance
    #236686
    helo_75
    f05 – pressure switch jammed on full
    pumps probably blocked, as always, with plug out, check filter/pump ( its at the bottom , at the front, under the kickplate!)
    #236687
    Re: indesit 5 flashes
    F05 suggests the pressure switch is jammed on full. Several possible causes, faulty pressure switch, blocked pump or filter, blocked pressure hose, faulty connections to PCB or indeed PCB fault itself. Please remove the mains plug before you put your hands inside.
    Hello, helo, hello 😆
