Indesit BAN12NFUK
  • #40346
    maltheviking
    Need a little help please
    Compresssor dead, I suspect the module. But not sure on the following as I have no wiring daig. 🙁
    On the evaporator there is an item clamped to top right with four wires,red/blue/two grey, is this a thermal fuse?
    Help with a wiring diag. would be most appreciated 😉
    #265868
    johnnyj
    Re: Indesit BAN12NFUK
    Normaly the module nice easy job to. jj
    #265869
    robbo1973
    4 wires are the cycling stat and o/load if these go faulty evap ices up,only comes with the heater changed a few but dead will be module changed a few.
    cheers chris
    #265870
    maltheviking
    robinsonrobbo wrote:4 wires are the cycling stat and o/load
    cheers chris
    Hi Chris, should both these be open circuit normaly? I have metered them and found no circuit or readings. 😕
    #265871
    robbo1973
    there are a few versions if i remember rightly one side should be closed(o/load) and i cant remember if the other closes at low temp or opens at high temp but if there was a problem with this you would get an iced up vap.
    #265872
    maltheviking
    Thanks Chris I will try a module first, not to pricey for a change 😉
