Re: Indesit BAN134NF (UK) F/F
The sensor changes value when it gets cold. The problem is that the defrost heater will not cover enough of the evap. You fix new one but start abit lower and leave it hanging underneath the evap. which solves the problem.
Also look along the drain hole in freezer if it has gone black on the plastic then the gutter heater has blown.
New defrost heater from :71008 – indec00259475 (includes new sensor)
New defrost heater upto : 71008 – indec00259476 (includes new sensor)
Gutter heater : indec00140585
Harness to connect the heaters togther : indec00141294
Hope this helps.
