indesit bci450 dishwasher
  • #61794
    mikehha
    good evening all espcially you hpt engineers.this d/w will run for anything from 4mins to 30 mins then it will bleep two or three times then stop you then can`t reset the program and no green lights show but mains light is on I have changed the module and still the same The other thing is the salt light is a steady flash even though the salt is full.any thoughts cheers. mike
    #347644
    loopey
    Re: indesit bci450 dishwasher
    wrong pcb fitted as from the looks of it , what was the origanal fault or code ? salt light means nothing as a fault code ? sounds like a usual no heat pcb fault , heater or cabinet stat , more likley the latter
    #347645
    mikehha
    original fault was m/c would sometimes go through but most of the time would stop .bleep .and go back to start.It does heat.and module no c00143214.
