Indesit Bearings
  • #31283
    subs
    Im after a bearing kit for a WD12XUK. Masterpart and Home Spares are both out of stock and Indesit are saying there are 2 sizes 26mm and 22mm and they are double the price. Can anyone enlighten me.
    Subs
    #230536
    richardable
    Re: Indesit Bearings
    to find out which size of bearings you need you will need to get the drum pulley off, not easy if it is bolted on with a round headed hex bolt, and measure the diameter if the shaft. other posters on this site may be able to tell you. if your machine has an external spyder its a tricky job, if internal spyder it’s even trickier!!!!
    richard
    #230537
    subs
    Cheers Richard! Its the external spider one, i did one a while back and it was a bit of a pig so this time i quoted the landlord top dollar, not fancying it and he still went for it 🙂
    Subs
    #230538
    johnnyj
    If you give the edge of the torx pulley bolt a couple of good whacks with a cold chisel, you will find the it will come of no bother at all i’ve never broken a Torx bit since a started doing this.
    #230539
    aqualectric
    There are 2 sizes of bearings and seals. To identify which kit you need, remove the pulley and measure the shaft diameter at the outer bearing. It will be either 26mm or 22mm.
    If 26mm use bearing seal part no. 082696. The spider is fitted with 6205 and 6206 bearings. Cheapest way to buy these together is BRG6091 from Connect (AEG kit; fits 560,633,2060 etc) and use the 082696 seal. Discard the AEG seal.
    If 22mm, use bearing seal part no. 096186. This spider uses 6204 and 6205 bearings. Cheapest way is the Hotpoint kit, fits all machines pre – WMA – eg: 95, WM etc. Fit the 096186 seal and discard the Hotpoint one.
    HTH,
    Steve.
    #230540
    subs
    Thanks for every ones help. Turns out to be 22mm bearings i need so your input steve helped me right out, ive got a few hotpoint bearings on the van just need to get the seal cheers.
    Subs 😀
