WDG 1095 102124184
How straight forward is it to replace the bearings on this machine?
Is it just a case of removing the bearing spider from the rear of the drum. I purchased a bearing and seal kit from connect, part code BRG3052. This comes with not only bearings but seals, rubber grommet type things and large washer plates. Not done this particular one before.
Any Help Please.
