Indesit CA 55 (UK) – freezer ok but fridge not cooling
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Indesit CA 55 (UK) – freezer ok but fridge not cooling
Viewing 1 post (of 1 total)
  • #98243
    pkreli
    Fridge Model is Indesit CA 55 (UK)
    Freezer is ok but fridge is not cooling – milk and food going off before their expiry date. Checked with a thermometer, fridge temperature was 13 degree C even on lowest setting. However freezer is -21 degree C.
    Compressor is running, all the time I think.
    I defrosted and also changed the thermostat, but didn’t fix the issue.
    I believe this is a wet wall design, in the fridge section, there is frost in the back plate and drain hole. I have unblocked the drain hole but this didn’t solve the problem.
    It seems wet wall designs don’t have cold air flow – I don’t find any internal fan or any air duct to flow cold air from freezer to the fridge and I cannot find anywhere to take off the back plate either on the freezer section or the fridge section – looks like it is a sealed / foamed. The evaporator tubes form the shelf of the freezer section.
    Any advice what could be wrong and how to fix this ?
    Many thanks
