Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › indesit carbon brush
- This topic has 13 replies, 7 voices, and was last updated 14 years ago by
electrofix.
March 28, 2012 at 2:24 pm #68679
Moderatortrying to source a carbon brush for this machine
WA101 uk ( may be WIA101uk)
46344830105 ser 705164705motor ACC
carbons are almost identical to sole carbons Qaultex CAR99 (zan part no 4006020152 )
but the carbon slopes in the opposite directionanyone any ideas before I butcher a pair of car 99
March 28, 2012 at 4:11 pm #372229jimca007
ParticipantRe: indesit carbon brush
Just cut the copper lead attaching the carbon the holder and reverse it so its pointing in the right direction, I’m not sure if this is frowned upon or not but done it hundreds of times with no problem
March 28, 2012 at 4:28 pm #372230electrofix
ModeratorRe: indesit carbon brush
that what i will do if i have to but i assumed there must be a correct part and if I get a customer asking for them its nice to know the answer
thanks
March 28, 2012 at 4:48 pm #372231Martin
ParticipantRe: Re: indesit carbon brush
jimca007 wrote:I’m not sure if this is frowned upon or not but done it hundreds of times with no problem
Hundreds of times?……surely not……really?……do you know why brushes have copper tails?….. :rolls:
March 28, 2012 at 4:54 pm #372232QUICK FIX
SAND PAPER THE EDGE THE OTHER WAY
March 28, 2012 at 6:27 pm #372233johnnyj
C00114885 cost more than the machine is worth. JJ
March 29, 2012 at 9:49 am #372234jimca007
I always assumed it was to ensure a good contact and secondly to hold them in….. always open to new info tho so …..
March 29, 2012 at 12:07 pm #372235Martin
jimca007 wrote:I always assumed it was to ensure a good contact
Your assumption perfectly correct. :tup:
No tag = no contact and therefore only the spring and the metal guide are acting as ‘indirect conductors’ which will result in overheating and premature failure…….not good. 🙁
March 29, 2012 at 7:22 pm #372236suedehead1
Martin wrote:
jimca007 wrote:
I always assumed it was to ensure a good contactYour assumption perfectly correct. :tup:
and when the brush wears down the spring goes into the commutator
damages the motor blows the pcb and you can sell them a new machine.March 30, 2012 at 10:05 am #372237electrofix
johnnyj wrote:C00114885 cost more than the machine is worth. JJ
qualtex show this part number cross ref ro car99 which means the carbon face is still the wrong way
looks like its a cut reverse and resolder job
March 30, 2012 at 10:42 am #372238neilsukwg
Why not carefully (put yer glasses on) hacksaw the brush to face the opposite direction.
Ideally you would also use the same blade to slightly serate the brush, use a combing action with the hacksaw blade to help it bed in,
finish off by re-fitting and then bed the brushs in with some comm stick cleaner, also available from qualtexMarch 30, 2012 at 11:04 am #372239Martin
electrofix wrote:qualtex show this part number cross ref ro car99
Dave, in your first post you were uncertain of the exact model no of the machine. Can you clarify what the model is now? You mentioned also is was a “motor ACC” is that the make of the motor? (never heard of it before)
Lots of cranky advice here on how to bodge a brush in but I’m sure you’d like to do better than that surely to god. 😀
March 30, 2012 at 11:35 am #372240electrofix
was not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} percent on model at first. i had it down as WA101UK but could not find that number
have now got model WIA101uk from commercial code
March 30, 2012 at 4:39 pm #372241Martin
electrofix wrote:have now got model WIA101uk from commercial code
In that case it one one of these 3 options
C00273898
C00114885
or C00097255All seem to have the same exact profile as the CAR99. :con:
