INDESIT CERAMIC HOB ..MK64R
  • #53584
    richardable
    custimer says the front right hob dosn’t work. he has replaced regulator , no fix, so replaced hotplate no fix. either he has wrongly re wired the
    regulator or there is a hidden fault.
    can anyonr supply a wiring diagram for the hob? especially a wiring diagram of the regulator wiring..
    thanks
    richard
    #316532
    clyde
    Re: INDESIT CERAMIC HOB ..MK64R
    I would check the links in the terminal block first!
    #316533
    richardable
    clyde, this is a separate hob..no cooker/oven involved.
    all wiring from a terminal block to either individual hot plates
    or their associated regulator..no links apparent on the t/block.
    thanks
    richard
    #316534
    ray.t
    I have had one the same as this. Front right not working.
    I changed the reg and it still didn’t work.
    The one I had was a problem with the block. I think the live side of the block had about 3 connections on it even thought the live wire for this ring was connected to the block the bit it was connected to was not live.
    I moved the wire over one connection and it was fine.
    Ray
    #316535
    richardable
    thanks ray.t…will post result after next visit.
    richard
    #316536
    richardable
    thanks ray t…moved live and hob works a treat..
    first class tip
    richard
