Hello all,
Our Indesit has stopped working – there is power getting to it, as indicator LEDs are behaving as normal, but on starting a cycle, although the lights behave as if everything is normal, there is no sign of heat or the drum spinning. There is a quiet click which seems to emanate from the right-hand side of the machine when I try to turn it on. Was going to try thermostats etc, but I believe that the drum would still spin if it was simply a thermostat issue – is this the case? Any ideas what to check out? Filter and condensor cleaned v regularly and water emptied.
Indesit want £95 for labour (parts free) to sort it out…(!)
Thanks in advance,
Dónall
