Indesit condensor t/d motor humming
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit condensor t/d motor humming
  • #39500
    alro
    Hi gent
    have an idesit t/d same as hotpoint motor humming wont turn tried cap have 240v going to motor tried new motor same humms does anybody have wiring diagram for g74c t/d could be g73c, i have neutral on blue to motor 2 lives going to either side of cap when start button pressed
    cheers alro
    #262626
    wilf
    Re: Indesit condensor t/d motor humming
    should only be live to only one side or the other at any one time. check the timer
    wilf
    #262627
    agree with wilf
    neutral is a permanent connection and to get reversing live is fed to one side of the cap then the other
    try disconnecting the wire from timer to motor there are two of them one to each side of cap diconnect 1 turn on if no joy try the other one see if that gives you movement
    hope this helps
    kiddo66
    Is it definately the motor humming and not the door interlock buzzing because the locator pin is either missing or bent?
    #262629
    boselecta
    You should be able to start the appliance without the cap, does the motor start when the drum is forced by hand?
