indesit d/w idl530uk
  • #59270
    jimluxe
    hi chaps
    this machine runs through the complete cycle but will not heat .
    no error lights,heater is fine bottom right stat is ok and temp sensor on door is in place.the pcb shows no sign of the usual burning or dry joints.
    everything points to a pcb fault but this is a brand i dont normally work on
    (mates machine) so i am not sure if i am missing something.
    any advice would be much appreciated
    #337527
    Re: indesit d/w idl530uk
    jimluxe wrote:any advice would be much appreciated
    The search tool is a brilliant asset and if you type in IDL530 THIS is one of several handy answers that may be of interest to you. 😉
    Mind how you go. 😀
    #337528
    jimluxe
    Mind how you go. 😀
    thanks Martin
    your right! that search bit is brilliant
    #337529
    If no dry joint, try replacing relay. Cut open old one, you may find contacts burnt.
    Mike.
