No there’s absolutely no noise, the light stays on, I’m not sure if I should be contacting a plumber or an electrician? is the door lock micro switch easy to replace as I would prefer to try and fix myself or how can I find out if this is the problem?
THANK YOU!
Plumber, PLUMBER, :rolls: would you contact a domestic appliance engineer if your toilet was leaking?
Door latch switch is a common failure on these, it’s inside the door at the top, be very careful if you open it up, be sure to remove the mains plug and watch the sharp edges.
And if you did call someone who advertised themselves as an electrician 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of them would suggest you called a domestic appliance engineer.. 😉
