Re: Indesit D4000 WG stuck on rinse and water not heating
Quite a few possibilities with this I’m afraid – heater, thermostats, wiring or timer are all potential culprits.
The way this machine is configured is that at the heat position the timer is stationary. The thermostat, upon reaching temperature completes the circuit to the timer motor, which will then advance on through the programme.
If you are not sure how to use this info, check the Directories section for a local UKW engineer, or stick your postcode up in here and someone will pick up on it.
If you’re going to have a look yourself, pull the plug first.
