Indesit D41
  • #43280
    rocker
    Customer tells me the dishwasher fills, then hears a click sound like a relay then nothing happens, but will empty if programe re-set.
    It sounds like a pcb board fault !!, can anyone please confirm this or point me in right direction.
    Cheers john
    #276733
    timdowning
    Re: Indesit D41
    More likely circulation motor failure. The click may be a hum?
    You know how it is with customers mimicking sounds!!
    They will be holding the phone next to the the dishwasher if you ring back!
    #276734
    rocker
    Re: Indesit D41
    Thanks timdowning for your help, will check this out. John
    #276735
    rocker
    Re: Indesit D41
    Timdowning, you were spot on, circulating motor-jammed released now running ok.
    Cheers John.
