Can anyone help on this one?. On normal cycle (prog 2) machine fills and appears to start cycle then after a while 2nd. LED from left starts flashing. If door is opened at this point the interior is hot and steamy so heater must be working. All the posts I have found so far suggest fill problem, but if door is opened during cycle machine has water, it can also be seen going up plastic tube on rear.
If short wash (prog 3) is selected machine goes through complete cycle and finishes normaly. As the temp of the two washes is different is this a thermostat problem? or is there some other factor involved here?
Any help gratefully received.
p.s. where do I look for thermostats Many thanks
