Indesit D41 – not doing much at all except beep
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Indesit D41 – not doing much at all except beep
  • #26821
    Boosh2000
    The dishwasher seems to have stopped doing much at all except beep at me.
    The model is an Indesit Slimline D41UK Type Number LS 08-BIT100
    When turned on to any setting it lights up the relevent green light and then does nothing at all – doesn’t drain the dirty water at the bottom, doesn’t pump new water in. When I turn the dial back to reset I get 4 beeps. and none of the green lights stays lit.
    I’ve tried tipping the machine back and draining water out of it (maybe I didn’t do that well enough though), I’ve made sure that there’s water in the pipes and I don’t think that there’s anything blocking the filter of drain hose.
    Anything else I can try before I either get something new or call in a repair man?
    This forum and site gave me the confidence to change my washing machine drain pump myself, so I’m hoping you can help this time too.
    PS – I ought to say that the door hasn’t felt as though it’s been latching recently, although this didn’t seem to stop the dishwasher working.
    #211499
    hotpnt
    Re: Indesit D41 – not doing much at all except beep
    sounds like the door catch, you will be able to set a prog and hear the beep, but nothing else will happen till the door switch is made, could be the bar the door locks onto at the top, wiring or the door lock itself, all checked with the plug out of course
