Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Indesit D41UK leak
- This topic has 6 replies, 3 voices, and was last updated 20 years, 4 months ago by
andy2.
December 12, 2005 at 11:28 pm #14016
andy2
ParticipantHi – I attended one of these slimline dishwashers which has a leak. The water appears to be escaping through a hose which is open into the base. (a drain). As there are water marks that suggest this (even though i could not get it to leak at the time. Also for some reason the float switch has not operated to raise an error condition
Can anyone tell me please the purpose of this hose and where the leak is originating from. At first i thought it might drain water in the event of the level being too high but now not sure.
I would appreciate some help on this
Andy 😀
December 12, 2005 at 11:33 pm #157526iadom
ModeratorRe: Indesit D41UK leak
It could almost be the same answer as another post, there is a device , in the parts list it is called a ‘bodytop overflow’ a small round plastic thingy just behind the lower spray arm, it allows an overfill of the inner drum to flow into the base.
December 12, 2005 at 11:52 pm #157527andy2
ParticipantRe: Indesit D41UK leak
Thanks Iadom I did not see that post. The reason I began to doubt that it was for an overfill condition is because i poured extra water into the machine to simulate an overfill but no water came out of the hose. I actually covered completely the grey plastic thingy that has holes around it but did not get any water out ?? Is this the syphon device that SDL mentions
Quote:-
“she has prob pulled off or broken the syphon device this lets water into base pan if machine overfills, it screws in i think, “Andy
December 13, 2005 at 12:01 am #157528Penguin45
In theory, an overfill should leak down the tube. I’ve been to so many of these where they leak from the tube seals to the tub (It’s a screw fit).
December 13, 2005 at 12:23 am #157529iadom
funny thing is, in the Hotpoint DWF40 derivative, what appears to be the same part is called a cap, with a different part number. Had one of these on which the pressure sensor had blown out of the small rubber diaphragm hose and flooded the base last week.
December 15, 2005 at 12:17 pm #157530andy2
Thanks gentlemen for all your help, so far this dishwasher has not leaked again so i still do not know why it did.
Andy 😀 😀
December 15, 2005 at 4:45 pm #157531iadom
Over soaping due to using 3 in 1 or 4 in 1 tablets ???
