Just called to two of these dishwashers, both with the same fault.
Tripping the RCD in fuse box.
when I took the bottom cover of there was signs of water overflowing.
Is this a common fault with this model? is there an easy solution?
Sorry if this a novice question but I’am still learning with dishwasher.
The easy solution is to advise your customer not to buy an Indesit. All to common fault on this and the Hotpoint/Ariston derivatives. The list of possible causes is quite extensive as well. Using 3 in 1, or 4 in 1 tablets can cause it in certain areas. Try a search of the forum, lots of threads on this problem such as this one. http://www.ukwhitegoods.co.uk/modules.p … dishwasher
