My dishwasher leaks through the lower door seal. I have removed the front panel from the door and can see the water splashing up everytime the sprayer goes around.
After dismantling the door i noticed one end of the seal had come lose. I put it back in and used some plyers to crimp it in place however once put back together it still leaks.
The seal is not split do they just wear out as i cant see any obvious damage? Also how easy is it to replace, do you need a special tool to crimp the metal lip over the seal?
Thanks.
