indesit d66s dw door seal
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts indesit d66s dw door seal
  • #58625
    gandh1
    has anyone got an exploded diagram for the door assembly for one of these. the part listed by connect for the lower seal does not look anything like the one fitted to this. there is an obsolete part but it looks identical to the current spare thats listed, and again, nothing like the original…
    cheers in advance
    #335137
    Re: indesit d66s dw door seal
    Lower door seal kit. C00056475
    #335138
    gandh1
    jim im afraid thats the same one thats already turned up from connect 🙁
    it doesnt resemble the original part thats there, and theres no “this is a modified part” sheet either :hmm:
    so unless im missing something, would i be right in assuming this is a modified design, in which case do you know if indesit have any fitting instructions that go with it? i know it appears to be pretty obvious. just wanna make sure.
    also bit miffed actually just noticed theres no clips in the pack either… i have a nasty feeling this has been out before 👿
    cheers, rich
    #335139
    gandh1
    double post
    #335140
    I think that is the correct one, not done one for a while but the original is sandwiched between the stainless and is impossible to fit. Cannot remember how but it didnt take long to work out.
    #335141
    Never had to change one, they don’t normallay last long enough. :rolls:
