Hi there fault is not heating the water,Heater unit was replaced but still no joy.With the heater unplugged i tested the connector and it has 240v present during the heat cycle. I have put the model number on Indesit web site too see if it has a seperate temperature sensor or cutout but according to them they dont list it.Has anyone else had the same problem,any help would be appreciated :eeek:
Moved to correct forum, you are listed as trade but posted your question in the public forums.
The pcb is a strong contender for your fault, don’t have the manual for this machine but a lot of them are switched in the neutral so having a live feed to the heater is only half of the circuit.
Was the displaced heater tested for continuity/resistance?
