Home › Forums › Public Support Forums › Help And Support › indesit dfp27b1 dishwasher mid cycle fault
- This topic has 30 replies, 3 voices, and was last updated 5 years, 8 months ago by
qwer.
August 17, 2020 at 7:06 pm #471026
Moderatorso if you try to run any other programme what happens ?
do programmes take longer than they should ?
does it heat because the pre wash does not ?
August 17, 2020 at 8:50 pm #471027qwer
ParticipantRapid wash (40 mins) as an example 20 mins in pause light comes on and so do red salt/rinse aid leds. The machine just hangs no heat the programme does not finish. Stuart
August 17, 2020 at 10:09 pm #471028electrofix
Moderatormay be a fault code
any other light on ?a pic would be good when it stops
dave
August 17, 2020 at 10:40 pm #471029qwer
ParticipantI’ll upload tomorrow stuart
August 18, 2020 at 8:22 am #471030electrofix
Moderatorif the pic is too big then you have to host on an external site and post a public link
August 18, 2020 at 7:42 pm #471031qwer
ParticipantNot on any external upload sites. Tried reducing the size of the image to 16kb and I keep getting told I’ve run out of upload quota despite not actually posting an image!
August 18, 2020 at 8:45 pm #471032electrofix
Moderatori reckon thats fault 5 which is a pressure switch fault
the pressure switch determines water height
find the switch and make sure all the tubes to it are clear
https://parts.hotpoint.co.uk/product/dishwasher/taps-valves/C00274118
August 18, 2020 at 9:37 pm #471033qwer
ParticipantMy problem is I’ve unscrewed panel yet can’t fully remove it because part of the plastic facia is attached to the panel. I’ve tried gently pulling but fear breaking the plastic. Anyadvice how to remove please? stuart
August 18, 2020 at 11:05 pm #471034electrofix
Moderatornot sure about thid one but will take a guess
on the later ones the pcb is under the door in a drop down panel. the top of this panel sticks to the sound deadening and has to be eased away to hinge down
is this what you mean
June 7, 2023 at 8:23 pm #471035Potato
ParticipantHi, i’m late to this one but I have the same machine with the same symptoms and the diagnosis makes sense. My problem is I can’t locate the pressure switch inside my machine anywhere for me to test/replace it.
is there a service manual that has an exploded view somewhere, or does anyone know where it is located?Many thanks!
June 7, 2023 at 8:46 pm #471036electrofix
Moderatorwell since you have a different machine we need a make and model
June 8, 2023 at 5:41 am #471037Potato
ParticipantSorry if I was unclear, my machine is the same as Qwer’s, an Indesit Dfp27b1.
June 8, 2023 at 9:23 am #471038electrofix
Moderatorwas just double checking if it had a pressure sw
from memory its on the bottom right side
June 10, 2023 at 9:06 am #471039electrofix
Moderatorok we need to do more checking
looks like yours may not have one
to be certain i need more numbers
model no ( which is above but check there are no extra digits) commercial code and serial no
all on the label
June 11, 2023 at 10:42 am #471040Potato
ParticipantThe numbers and serials on the back aren’t labeled up to explain what they are, so I’ve just copied them down and hopefully you’ll recognise which ones you need.
Dfp27b1uk 400011285889
4000112858890200109070607835
769990892455040532451927032424
20190706
06/07/2019
Many thanks!
