Home › Forums › Public Support Forums › Help And Support › indesit dfp27b1 dishwasher mid cycle fault
- This topic has 30 replies, 3 voices, and was last updated 5 years, 8 months ago by
qwer.
August 8, 2020 at 12:09 pm #98139
qwer
ParticipantHi My indesit dfp27 1b pauses mid cycle with salt and rinse aid led flashing red. lso it is stuck on a drain cycle yet no water remains in the machine .
August 8, 2020 at 12:21 pm #471012electrofix
Moderatoron most dishwashers if the unit leaks into the base where the motors are, there is a float which stops the programme and starts the pump which wont stop till the water is removed
you need to get into the base and if there is water there mop it out and try it again. if it repeats this then you would need to find the leak thats causing it
August 8, 2020 at 4:05 pm #471013qwer
ParticipantThanks I will try. Btw It’s my mum’s machine the filter was full of food the fine filter was full of grease and the drain hole had pieces of plastic wrapping in it! Could that have caused leaking?
August 8, 2020 at 4:39 pm #471014electrofix
Moderatorposs might be cause
are the bars free of debris as if some of the holes are blocked the ones that are left have a lot more forceDave
August 8, 2020 at 4:58 pm #471015qwer
ParticipantThe bars? I cleared the filters and what I could see in the drain hole. Cheers
August 8, 2020 at 5:00 pm #471016electrofix
Moderatorthe bars are the rotating bars that do the cleaning. these have holes in them where the water is jetted onto the plates
make sure the holes are clear
August 8, 2020 at 5:13 pm #471017qwer
ParticipantWill do. Won’t be opening up machine til next Sat is easy to access motors? I never thought blocked cleaning bars would cause a continuing drain cycle. I’ll let you know how I get on next Sat thanks for your help have a good weekend. Stuart
August 16, 2020 at 10:07 am #471018qwer
ParticipantI cleaned out bars they were not too bad. However I did not know how to access sump area is it via the side panel? I also noticed when it’s on a mid cycle drain pause if I open the door this continues. If I remove filters as this is happening water is jetting into the drain hole is this normal? Thx
August 16, 2020 at 11:49 am #471019electrofix
Moderatorwhat do you mean by the drain hole ?
August 16, 2020 at 2:57 pm #471020qwer
ParticipantYou know where the filters are housed the water drains out there. stuart
August 16, 2020 at 3:27 pm #471021electrofix
Moderatorits the word jetting that confusing me. there may be a bit of water return but al long as the water goes till the pump draws air then its fine. when the pump stop i expect around 2 inches of water in the sump
August 16, 2020 at 4:15 pm #471022qwer
ParticipantYeah wrong word used but water is in coming stops after a fews minutes but the machine remains paused and salt/rinse aid lights are flashing.
August 16, 2020 at 5:44 pm #471023electrofix
Moderatorhow much water is in the machine when it stops
with the filter in can you see it ?Dave
August 16, 2020 at 6:25 pm #471024qwer
ParticipantNot too much you can see it with filter out not sure out but I can have another look Tuesday
August 17, 2020 at 6:43 pm #471025qwer
ParticipantWater just over the bottom of the filter. I took a panel off no water in base the clear plastics had some water in them. The only program that runs correctly is the prewash. stuart
