Indesit DFP58T94AUK… ‘door’ message
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Indesit DFP58T94AUK… ‘door’ message
  • #97147
    TheOldBloke
    Hi All,
    Having a problem with the dishwasher and am getting fed up licking plates clean, so thought about getting it fixed.
    Simply put dishwasher will not start.
    There is power to the unit, the display is working (am able to cycle through options) but when I press the ‘Start’ button, I get a ‘door’ message scrolling across the screen and that’s it.
    Had a pretty good trawl through the web and can’t seem to find anything, foolishly phoned Indesit to see if they could explain what it meant, only to met with “did you want to book a repair ?” grrrrr….
    I checked seals, obstructions, seating of door, closed it slowly, slammed it shut etc…
    I opened the unit to check connections to door interlock – fitted a new one…. but still get the ‘door’ message scrolling across the screen.
    I humbly throw myself before your collective wisdom…
    The Old Bloke
    #466320
    if you get fed up of licking plates suggest you get a Labrador. they will lick any number of plates for hours
    as for the problem, its obvious the machine thinks the door is open, you say you have changed the lock unit so now you need to check the wiring back to the board
