My Indesit DG6145WG (6 years old) has developed a problem. On all of the 4 available programs it starts with a drain (that’s normal) but then the fill only lasts a few seconds and then the heater element switches on straight away even though there is a minimal amount of water there. This results in hissing etc. as the small amount of water splashes the element from the sprinkler arms. Also, this happens on all 4 programs including those which start with a cold rinse and therefore shouldn’t need the heater (I would have thought).
The lack of water is possibly due to a problem with the level sensor. But why does the heater always switch on? I assume the two problems are connected but I don’t know how.
Any suggestions would be gratefully received? Many thanks in advance.
