Re: Indesit DI 61 – Controller NO LED’s
Now I’ve had my little bit of sarcastic fun I have moved your post from the Washers & Dryers forum to the correct forum. 😀
You need to check if you have a circuit of any kind going into the PCB, mains plug removed and multimeter time, check door switch again first, if they seem OK then you could have another faulty PCB . 😥
Is there any sign of damage on the PCB that may have been caused by a faulty component such as the heater?
