indesit di 620
  • #36453
    Razor1
    Hi Guys , got a proplem with my indesit di 620 , The lights 1 & 2 are flashing . Any help would be appreciated .
    Thanks alot , Ray .
    #251042
    Re: indesit di 620
    1+ 2 is a drain time out error, possible drain pump blockage or obstruction.
    Razor1
    Re: indesit di 620
    Jim Thanks very much for your help and fast reply . Just wondered how id go about unblocking the machine or how much the repair would be if i cant do it meself . All the best , regards , Ray.
    #251044
    Re: indesit di 620
    The Indesit Company will charge you £90. Your local Independent will charge you less – check if you decide to make an appointment. Use the repairs@ link on the left for a local repairer.
    If you’re doing it yourself, removing the right hand side panel usually gives you enough access to get at the pump.
    Power off first, of course.
    Razor1
    Re: indesit di 620
    Thanks so much Penguin45 for your advice.
    Ill have a go at doin it meself now youve pointed me it the right direction . Cheers again lads for your help.
    All the best , Ray.
