Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Indesit DI 620 Leaky door – driving me nutty
- This topic has 6 replies, 5 voices, and was last updated 17 years, 1 month ago by
Halfcrazy.
February 25, 2009 at 5:15 pm #43749
Halfcrazy
ParticipantThe door leaks on both left & right hand side at bottom. Doesn’t do it always. Seals are fine & door looks like it closing properly. Always done since new & now not in guarantee – i know durrgh! Read on one site that it could be because the salt setting is on max as default from factory. How do I set the salt setting? Does this make sense? Any other suggestions? Could this be one of these faults that just goes on and on!! Had a guy round to look at it & he did just that – looked at it! Said he wasn’t going to try to repair a fault that obnly leaks some times! Do I need to get a new one?
February 25, 2009 at 8:15 pm #278409Dales-Electronic
ModeratorRe: Indesit DI 620 Leaky door – driving me nutty
Check that the spray bars are going around. How – switch it on listen for the water swish, open door set both top and bottom bars front to back close door listen again for swish of water and open door again. Look and see if they have moved. If they haven’t moved you have a spray bar problem which is causing the leaks. hth
February 25, 2009 at 8:34 pm #278410kiddo66
ParticipantRe: Indesit DI 620 Leaky door – driving me nutty
Where abouts in the UK are you.? Your problem could be caused by use of 5in 1/3 in 1 tablets and too much salt.This would cause overfoaming which would lead to leaks from the door.HTH
February 26, 2009 at 5:46 pm #278411Halfcrazy
kiddo66 wrote:Where abouts in the UK are you.? Your problem could be caused by use of 5in 1/3 in 1 tablets and too much salt.This would cause overfoaming which would lead to leaks from the door.HTH
Hi didn’t quite understand yr abbreviations – do you mean 3 in 1 tablets. I just fill the salt up to top as I have always done with dishwashers. I live on south east coast. Using 3 in 1’s but it does it whether i use 3 in 1’s anyway! grrgh
March 6, 2009 at 10:12 am #278412Halfcrazy
Dales-Electronic wrote:Check that the spray bars are going around. How – switch it on listen for the water swish, open door set both top and bottom bars front to back close door listen again for swish of water and open door again. Look and see if they have moved. If they haven’t moved you have a spray bar problem which is causing the leaks. hth
Hi thnak for yr reply. I tried what you suggest & the spray bars are going round. Any other suggestions??? Still wet floors!!
March 7, 2009 at 1:11 am #278413Penguin45
Multi-function tablets froth like crazy and really just don’t do what you think they do.
The next step is to remove the decor door and door outer panel. This will reveal the bottom of the cavity and the bottom door seal. With the power off, clean everything that you can see. Stand well back and run the machine and see if the water is still shooting under the door seal. The front edge of the cavity occasioanlly bows out with the heat – pushing it back may fix it if you’re lucky. Failing that, you may be looking at replacing the door inner panel, complete with bottom seal. Never done one or know of anyone who has – nasty, expensive job.
Good luck,
Penguin45.March 8, 2009 at 2:28 pm #278414jonnieboy
hi
indesit had a problem with this model does the leak occurr late on in the programme like the hot rinse cycle , does it tend to be foamy water? if it does its the 3 sided door seal is too long and causing a pressure buildup within the wash chamber on the hot rinse carefully cut the seal at both ends so that its about 1 inch below the frame it sits inside this allows the pressure to escape as air rather than water
the reason you still want some seal below the metal frame is too save you slicing your fingers off when cleaning as i think the bottom of the frame was made by gillette 😀remember only do this if your problem is as above
