Re: Indesit DI 620 not draining
Pump blockages are the most common cause of this problem, small bits of glass, bone, plastic. wood etc will easily stop the pump. As this machine is integrated your biggest problem may be getting it out. Once you have it free, remove the mains plug, place several towels on the floor and lay the machine down on its left side ( looking from the front) onto the towels, remove the base taking care with the wiring to the float switch and follow the grey plastic drain hose into the machine you should be able to locate the pump. Fairly easy from there onwards.
NB. The second light flashing is supposed to indicate a fill valve fault.
