I’m having problems with my Indesit DI 67. When switched and dial turned to a programme it sounds as though it has started and then the Pre Wash light flashes and it all grins to a halt. The manual advises ‘call for technical assistance. Can I sort this myself?
It sounds like the anti flood switch has been activated, your dishwasher may have a leak or may have overfilled – have a read through the other indesit posts in this forum this is a fairly common querey.
If you are unsure get an engineer to check it out for you.
😀 Thanks to this forum I have fixed my dishwasher. I guess it must have been the anti-flood switch activated as a result of an overfill as I pulled the dishwasher out, tilted at back and forth a few times (as per a recommendation by a previous enquirer) and it is now working fine. Can an overfill occur as a result of a two year old turning the programming switch round and round during a wash cycle?
