i had a problem that the heater was not heating the water so i replaced the relay on the pcb with one from maplins JM67X. since i have replaced the relay when i start the dishwasher after about 1 minute the solonoid on the dispenser clicks to open the flap then keeps on clicking for about 2 minutes. shoud i have replaced something else with the relay.
i had the leds flashing on the panel after i did some research on what the fault was it said faulty relay or element. i tested the element to be ok and someone listed on this site that relay JM67X from maplins.co.uk is the same.i have not got the original to compare it with anymore.
do you think it is control pcb or dispenser solenoid that is faulty?
