Does anyone have a definition of the cycle light error codes please ?
In particular – Indesit DI62 Dishwasher – On all programs. Set Program, close door, motor starts up and residual water pumps out. Motor keeps running and program doesn’t start. Open door again and motor stops and program 1 light flashing ( as if program 1 has completed).
Flood protection activated – the base under the machine has water in it. Drain it off to reset the float switch. If it repeats the problem you’ll need to find the leak.
Penguin45 wrote:Flood protection activated – the base under the machine has water in it. Drain it off to reset the float switch. If it repeats the problem you’ll need to find the leak.
A thousand apologies for raising a thread from the dead, but I’m having the same problem but can’t see exactly how to access the base tray to drain it.
