Indesit DI620
  • #29716
    streety44
    My Indesit DI 620 dishwasher is 14 months old. and has stopped working. The bottom tray is full of water. When I epmty the water by hand the washer will begin a cycle but shut down after a minute with the tay full of water. Ive tried blowing the drainage tube through and it appears clear. The indicator lights say call an engineer. Any suggestions before I do so???????
    #224209
    Re: Indesit DI620
    L-R, 1-4, which lamps are flashing?
    streety44
    Re: Indesit DI620
    lamps 2 and three. I believe these are the ones that say call an engineer?
    #224211
    Re: Indesit DI620
    No fill detected in the time allowed…….
    Water turned off, fill hose kinked/crushed trapped or inlet valve failure are all possibilites. The first two you can check easily enough yourself.
    Power off if you need to investigate the water valve.
    streety44
    Re: Indesit DI620
    Thanks for that. Will give it a go and let you know 🙂
