Indesit DI620
  • #32339
    philes
    Hi, have a DI620, sometimes it runs fine of all programs, then it will just stop after running the drain pump at the start of the cycle, not take water in, and just flash the 3rd light from the left !
    Have checked all things like drain, hose, plumbing and the like, all ok.
    When it works it works fine, but then plays up.
    Ohhh, and theres no water in the flood try underneath the machine, so any ideas what the fault light means ?
    #234731
    Re: Indesit DI620
    Suggests a faulty thermistor/temp sensor. Comes as part of the control module on certain models, also two different PCB’s neither over expensive. will need full serial number to ID correct part.
