Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › indesit di620 d/w
- This topic has 10 replies, 7 voices, and was last updated 16 years, 6 months ago by
hilly.
October 12, 2009 at 5:23 pm #49270
hilly
Participantmachine was reported as not heating so i did the usual, heater ok, stat in back corner ok, door loom ok, so i ordered a pcb like i have done many times before, fitted it and still have same fault?? i had to leave that day so ive rebooked it any advice before i go back gratefully recieved :bang:
cheers paul
October 12, 2009 at 5:43 pm #299378johnnyj
ParticipantRe: indesit di620 d/w
If it finishes programe without heating 9 times out of ten it is the pcb, which pcb did you fit and what is the ser n/o as i’m sure there is 2 on that model, jj
October 12, 2009 at 7:30 pm #299379hilly
the no’s on machine are 70316 0966 37303511100, and the no’s on the box of the replacement is c00143222 timer bit100.1 ‘f6’ rhos + n104504
hope this sheds some light on itcheers paul
October 12, 2009 at 9:35 pm #299380iadom
ModeratorRe: indesit di620 d/w
Thats the correct one.
October 13, 2009 at 7:10 am #299381hilly
cheers i’ll go bang my head a bit more now 😕
thanks for the replies
paulOctober 26, 2009 at 6:44 pm #299382hilly
still baffled by this one we have tried another new pcb on it with no joy??
we had another pcb off a different model and tried that on it it wouldnt reset and was stuck on one prog but it did heat up!! so my thoughts are still with the pcb?? :bang:????????paul
October 26, 2009 at 10:39 pm #299383bubs
Try the rear screw on stat, had one give me intermittent heat problems last week.
GraemeOctober 27, 2009 at 6:48 am #299384timdowning
I’ve got one of these to repair.
The fault is the same no heat.
I’m reluctant to repair this one because the customer says the machine has never heated from day one. They had indesit out who said there was nothing wrong.
I’m ordering a new board for it, as everything else rings out ok, but have got a bad feeling about it.
If you can get the truth out of your customer maybe the scenario is the same??
October 29, 2009 at 7:49 pm #299385hilly
got no conclusion for this one gonna bite the bullet i think and go and deliver it back and tell them to get indesit in or buy a decent machine,
i hate being defeted but ive spent enough time on this one 😥 😥October 29, 2009 at 10:56 pm #299386TELL
check the high pressure sensor, on connect site pt no.5045173458406. just had similar fault on belling d/washer see forum, trade spares posted by tell, read re-i’m back again belling dw604, might help you could be same intermittant fault.
TELL..October 30, 2009 at 8:32 am #299387twinspark
main motor can give no heat fault on this model 😀
