Indesit di620 decided to throw its hand in / spit dummy out
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Indesit di620 decided to throw its hand in / spit dummy out
  • #76612
    farghi
    Good Afternoon Good Sirs and Ladies
    I have a problem with this dishwashers
    1.Fault codes flashed up and water wouldnt drain
    2. Emptied manually
    3. Buzzing coming from underneath when turning on
    4. Fault codes would not clear
    5. Extracted front door securing screw from pump !
    6. Reassembled turned on no lights on program buttons power led on
    7. Pump tested on bench runs ok
    8. When powering on at on switch on machine cold feed solenoid hisses then cuts off 1/4 second
    9. Pressure wheel thingummy on side spinning when water tries to enter
    10. Main water pump is free but not operational when manually filled machine and turned on
    11. Now ran out of ideas
    12. I suspect something has blown when pump was jammed with door securing screw
    Any help would be gratefully appreciated
    #398918
    farghi
    Re: Indesit di620 decided to throw its hand in / spit dummy
    Good Afternoon Eminent Technicians
    I hope I didn’t offend anyone by addressing you as Gentlemen and Ladies, I was trying to be pc and inclusive !
    So as above does anyone have any ideas re above
    Many Thanks
    Farghi
    #398919
    Take a look at the PCB.
    #398920
    farghi
    Thanks Martin
    I suspected this as they dont have a great pedigree!!
    Soit looks like Ill bite the bullet and get a new pcb. Ill look up the serial number and refer to previous posts which one I require thanks
    Farghi
