Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Indesit DI620 dishwasher
- This topic has 6 replies, 2 voices, and was last updated 17 years, 11 months ago by
suedehead1.
April 26, 2008 at 4:11 pm #36314
suedehead1
Participanthi, i fitted a new 100 bit card to this machine as it wasnt heating and the heater was ok.
the new card didnt initialise properly and now it wont reset, the sheet supplied with the card doesnt explain what to do if it doesnt work properly.April 26, 2008 at 4:34 pm #250478iadom
ModeratorRe: hotpoint DI620 dishwasher
From the manual. For Hotpoint FDW60/80 etc but it is the same basic card.
When this card is fitted it may go into factory test cycle.
To eliminate test cycle.
Switch on the machine and with the door closed wait for the test cycle to start up. ( 2 LED’s will start to flash)
Switch off the machine and wait for 15 seconds.
Reset the test cycle.
Now this is the bit that gets tricky, in the manual it says turn the selector knob to reset and leave for five seconds, the only flaw in this instruction is that these Hotpoint machines are all push button so don’t have a selector knob.
All I can suggest is holding the start/reset button for five seconds if it has one.
It does state that all these actions are to be carried out as quickly as possible and the 15 seconds must be exact.
Worth a try.
PS. Just spotted that I had replied to your other post in the public forums. 😳
I have deleted your post as well a my reply. 😉
PPS. I have edited your post, I’m sure you mean an Indesit. 🙂
April 26, 2008 at 5:36 pm #250479suedehead1
ParticipantRe: Indesit DI620 dishwasher
thanks for the reply i did try and hold in the start button for a long period if time i will go back and have another go i am starting to thing the pcb i got from qualtex may already have been fitted before, i think my only option may be to get another pcb.
April 26, 2008 at 5:52 pm #250480iadom
ModeratorRe: Indesit DI620 dishwasher
There used to be some info about these modules within Partfinder, something about locking out the new PCB if the original fault had not been cleared. From memory it mentioned something about having to put the old module back in, clearing the fault and then doing a reset.
Had a quick look through Partfinder for a few different models with the 100 bit PCB and cannot find that info anymore, sorry.
It does say the 15 second pause is critical.
April 27, 2008 at 5:02 pm #250481suedehead1
thanks again i still have the old pcb i will stick it back in and try again regards sh1.
April 28, 2008 at 7:01 pm #250482suedehead1
hi,
i fitted the old board then refitted the new board followed leaflet exactly and it worked.
customer phoned me to say it has gone throegh 2 loads and is working ok.
thanks very much.April 28, 2008 at 8:03 pm #250483iadom
Result. The power of UKWG’s strikes again.:tup:
