The door catch on my DI620 failed and I regret that my problem is self inflicted! In replacing the catch, i could not release the top panel without unscrewing the full interior panel (it’s fully integrated and the cosmetic panel was preventin removal)Mistake! The door seperated v quickly, disconnecting several leads in the process. Is there a link to the repair manual showing the wiring or could someone offer advice on which leads connect where please? One particular lead is a black wire with a white plastic bit on the end which i believe connects to the detergent dispenser, but where? Thanks in anticipation.
Even we struggle to get wiring diagrams for many makes and there is no such thing as a repair manual usually and, certainly for any Indesit product there isn’t one available to the public or us.
The black wire/wires are for the NTC (the small white plastic doofer)
It is located behind a small clip near the dispenser, usually to the right, it just slots in, it should sit flush to the inner door panel to sense the temperature.
