Indesit DI620 help!
  • #43421
    synaesthesia
    Machine has stalled, won’t shift programes to start, cannot reset, prog. 2 light flashes alone.
    any ideas?
    #277220
    Re: Indesit DI620 help!
    Which light, do you mean light number 2 from the left?
    synaesthesia
    yes.
    #277222
    Odd one this, light two flashing is supposed to signify an inlet valve fault.
    It could be a faulty valve or other spurious faults such as the flowmeter, pressure switch, heater being down to earth, poor module connections, even a faulty module.
    Is the tap turned on?
    kiddo66
    The heater will probably be down to earth.For some reason a short circuit heater triggers the board into thinking the inlet valve is at fault.
