Re: Indesit DI620 Lights
ousewanderer wrote:My Indesit DI620 appears to be working perfectly ,
Thats something of a novelty these days 😥
Neons 2+4 suggest a heater related fault, the tube elements on these do fail often, yours should however have an element that you can see inside the tub, does it look mishapen or distorted in any way?
These codes are only a pointer to the general area of the fault, further investigation with the correct test equipment is needed.
Please remove the mains plug if you intend to proceed yourself.
