Indesit DI620 module problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit DI620 module problem
  • #62009
    Johnnyboy
    Hi folks, customer says no heat so has to be PCB( dosent it? ) as heater and stats ok, replaced module as it is integrated switched it on closed door and powered it up from the socket, test prog starts lights 2+3 lit steady unable to cancel test, wait until it is finished and still wont select a prog lights 2+3 on steady. Refit old module away it goes still no heat, Another module arrives and exactly the same happens HELP!!!! what stupid obvious thing am I missing.
    Yours sheepishly Johnnyboy
    #348394
    Re: Indesit DI620 module problem
    Two different PCB’s, have you got the right one?
    Before serial number 61020.0000 its a C00143206.
    After serial number 61020.0001 its a C00143222.
    Did you check the heater for insulation as well as resistance/continuity?
    TBH the large exposed elements are not as prone to failure as the tube one though.
    johnnyj
    The 100bit tiomers have a small plug on the side of them some are connected with wiring others may just have a resister connected to it, if you have forgotton to take this of the old board and fit it to the new one, you will not get it out of the test mode as this plug identifies which model of appliance it is, i have had a couple of cases when this has happened.
