Indesit DI620 Not heating but element OK
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Indesit DI620 Not heating but element OK
  • #100363
    Murray46
    The breaker for the sockets tripped when the dishwasher was set going. I isolated it and meggered the heater. The insulation readings to earth were low. Got a replacement heater and connected it back up. Set it going and now it runs a complete cycle but doesn’t heat the water. No voltage is getting to the heater. Does anyone know if there is a fuse somewhere for that? Or any other suggestions would be appreciated.
    Seems something else may have been damaged by the heater when it tripped the supply.
    #480319
    kaibart
    The heater will get 240v from the pcb so if its not getting it the pcb may be faulty but its worth checking the wiring in the door to check if there’s a broken wire
    #480320
    Murray46
    Thanks. The update on this, is that I powered off and on again and did a reset. And it worked OK after that. It is possible the faulty element threw up a fault on the pcb. And a reset was required. Fingers crossed!
