noticed dirty dishes not as clean as normal and did not seem dry as normal. Noticed control panel light 4 flashing fast (had been on wash 2).
Ran the machine empty and notice water not heating up and at end of cycle no blast of steam when door opened.
Am I correct to assume the element has packed in and needs replacing?
Is replacement as straightforward as it looks – loosen the two securing brackets then a pull out of socket – then do reverse steps with replacement parts.
Thanks.
