indesit DI620UK water leaking from door edge
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries indesit DI620UK water leaking from door edge
  • #76620
    slyp98
    HI this lovely machine has started to leak water from the door gutter channel onto the floor , checked seals all fine , could there be too much water in the tub ? its up to the bottom of the salt container cap
    #398948
    timdowning
    Re: indesit DI620UK water leaking from door edge
    Did you check to see if the lower spray arm was split on the moulded seam?
