Indesit DIF 04
  • #85265
    washermanuk
    Ok had flashing lights as per normal 😕 Replaced heater pump and motor rewired heater connections!! Just wondering should the fault code reset on its own once pcp finds a circuit or is there a reset procedure? Because lights just keep flashing and do nothing to stop it!!!! :rolls: many thanks Brian . Ps I did try and tell customer not to get it repaired
    #428224
    timdowning
    Re: Indesit DIF 04
    Errors should disappear when fault rectified.
    What’s the order of lights flashing?
    #428225
    washermanuk
    Re: Indesit DIF 04
    Cannot remember exactly? But think it was first and fourth light? Which I understood to be a heating fault? Found the plug connector badly burnt on heater contacts so I replaced heat pump part and rewired plug and the main wash pump motor as it was very noisy , I think I’ll check the pcb module sounds like that’s had it? Thanks for your help feels like a waste of time trying to repair stuff now
