Indesit dif 04 dishwasher
  • #74197
    ddirect
    Does compulsory drain, fills, then stops with
    Light 1-2-3 flashing
    Any ideas
    Darren
    #390416
    Re: Indesit dif 04 dishwasher
    ddirect wrote:
    Any ideas
    Read the Known Error codes thread, it’s been in there for almost two years. 😉
    #390417
    ddirect
    Read it checked wiring changed wash pump still have same problem,thats why i put this post up to see if there where any other answers to this problem. Thanks for looking.
    #390418
    ddirect wrote:Read it checked wiring changed wash pump still have same problem,thats why i put this post up to see if there where any other answers to this problem. Thanks for looking.
    Changed pump? According to the known error codes 1-2-3 is a water turbine (impellor) fault. 😕
    error codes
    #390419
    madangler1
    Likely board as Iv seen the water turbine fault a few times before and was the board.
    #390420
    ddirect
    Iadom to my knowledge is a water turbine impeller just another name for a wash pump or part of it?
    Thanks madangler1,
    #390421
    No, the water turbine, which is known as an impellor jug on Bosch machines and is used on several makes. It seems to cause most problems on Bosch and Whirlpool from my experience. I have seen them in BSH washing machines as well as the large Whirlpool washers.
    It is literally a small turbine situated just after the inlet valve, as the water enters it turns and generates a signal to the pcb to control the amount of water and monitor the flow.
    On the Bosch machines it is a separate part but on the Indesit/Hotpoint and also the Whirlpool it is built into the plastic, water inlet chamber.
    THIS is the common Hotpoint/Indesit one that fits your model. You can see the small turbine, bottom right in that picture.
    #390422
    ddirect
    Thanks iadom didnt notice it i know what your on about ive relpaced them before, but to be honest i never noticed it having seen it has a pressure switch i never looked.
    ill call back tomorrow and once again thanks.
    Darren
