Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Indesit DIF 04 not circulating water
- This topic has 4 replies, 2 voices, and was last updated 6 years, 12 months ago by
steverob1066.
April 12, 2019 at 2:10 pm #95749
steverob1066
ParticipantHi – I’ve had this machine for well over six years, and the only issues have been heater replacements, which I’ve found relatively easy to fix myself. (I know – maybe I’ve been exceptionally lucky.)
Now, however, there’s no water circulating. On start, I can hear the water entering the machine, and then a pause and then… nothing, except a quiet click – perhaps the thermostat relay clicking on? and a slow periodic hissing sound like a kettle warming up, which I am thinking is the sound of water heating up as the heater switches on and then off again. The machine gets warm but otherwise nothing else. The machine drains OK. In fact the machine seems to run its cycle but with no water. Not especially what you want in a dishwasher.
I am assuming the main circulating pump motor is shot – it had been getting noisier over the past weeks, but there are no rapid flashing lights, so I’m wondering if it’s something else. Thoughts?
A replacement pump is over £100 so I think that if that’s the issue, this machine is going to be replaced. Any recommendations for a budget built-in machine?April 12, 2019 at 2:20 pm #461243electrofix
Moderatoryou could strip it an see if anything has got caught in there jamming the motor
also there are 6 models with DIF04 in the model number. you need to make sure which one yours is first in case you order the wrong motor
April 12, 2019 at 3:31 pm #461244steverob1066
ParticipantOK- thanks- have had a look, and it’s definitely the pump. The impeller is stiff and graunchy so the bearings have disintegrated. The annoying things is the impeller is a sealed plastic unit which easily separates from the coil windings and electrics – but as far as I can see you have to buy the whole thing. If only someone would sell just the impeller…
April 12, 2019 at 9:04 pm #461245electrofix
Moderatorlooked up 2 of the models one had motor price £110 the other was £86 so to find out which one your is for definite we need all the numbers and any letters etc after the DIF04
April 12, 2019 at 10:27 pm #461246steverob1066
ParticipantThanks – I am thinking about starting again…
